Discussion topic: WiFi
This message was authored by: Ju_j18
WiFi
WiFi is dropping in and out, it's been getting progressively worse over the last couple of weeks. Have looked for problems, none present. Wires all connected ok, have reset router. No changes. I have had the router a long time, how often should they be changed? (Since April 2016)
thank you
Julia Davis
Re: WiFi
@Ju_j18
Could you post your router stats
