Discussion topic: WiFi
This message was authored by: Susab
Message posted on 09 Apr 2024 10:09 AM
WiFi
Setting up new broadband with sky, password is not working saying incorrect
Find out more
Message posted on 11 Apr 2024 11:25 AM
Re: WiFi
Are you using the supplied WiFi password from the rear/bottom of the hub?
Are you sure you are using the correct case/numbers/symbols?
I am NOT a Sky Employee
