Discussion topic: WiFi
This message was authored by: Zehra1
WiFi
My WiFi isn't connecting to my devices at home
Re: WiFi
@Zehra1 what are the lights on your Sky hub showing. If the internet light is amber it means there us no connection to the exchange. Run the connection test in the My Skyapp over a mobile connection as that will tell you if there is a known fault. If there isnt call Sky and report the fault.
