Discussion topic: WiFi wont work
Message posted on 27 Aug 2026 08:17 PM
WiFi wont work
WiFi won't work
Message posted on 27 Aug 2026 08:21 PM
Re: WiFi wont work
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
