Discussion topic: WiFi won’t work upstairs
This message was authored by: Jazmine11
You came out last week and upgraded the Wi-Fi to fibre but since then I can't get Wi-Fi on my mobile phone or iPad upstairs in the bedrooms the engineer moved the box into a different room where before it was always in the hall so I don't think it's got enough signal to reach up to the bedrooms so maybe I need a booster upstairs so I can do Wi-Fi on my phone
Re: WiFi won’t work upstairs
@Jazmine11
This is a customer helps customer forum so you are not talking to Sky.
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
