Discussion topic: WiFi won’t work, keeps disconnecting
This message was authored by: Stephbabybaby
For last few weeks WiFi connection has got worse. We are daily having to power off the hub box and then reconnect. Today we have done this 4 times and still not working!!
Re: WiFi won’t work, keeps disconnecting
@Stephbabybaby See the link below about the hub lights, also the service checker and the diagnostic for you to check.
This should determine if there's an identified fault affecting multiple households.
Avatar for Stephbabybaby
Thank you!!
done all that, lights on hub but not connecting, they are sending engineer out!! So now I'm stuck for 2 days!!
