Discussion topic: WiFi won’t connect
This message was authored by: Ross137
WiFi won’t connect
My WiFi is not connecting and when I try to check connection in the sky app keep getting an error message
Re: WiFi won’t connect
@Ross137
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
