Discussion topic: WiFi weak
This message was authored by: Emski79
WiFi weak
My WiFi is very slow and sometimes does not work at all
Re: WiFi weak
@Emski79  Are you talking about the speed you get or the coverage throughout the property?
Avatar for Emski79
Re: WiFi weak
Hi,
It's the coverage. It is so weak. I have run all the test and they come back fine but it is so bad.
