Discussion topic: WiFi very poor
Message posted on 02 May 2026 07:37 AM
WiFi very poor
WiFi has slowed down over the last few weeks. Nothing has changed physically in the house. No increase in number of connected devices and router position hasn't changed but WiFi is slow and having to switch to phone network instead of WiFi to use internet. Will sky change the router or issue free extenders/boosters?
Message posted on 02 May 2026 07:48 AM
Re: WiFi very poor
@mcholt no Sky wont change the hub just because your WiFi is struggling. As a first step reboot your hub as that can help,as the most likely issue is interference and the rdbootvshould find the best channels to use. However any relief maybe temporary as the real solution is improving the Wi`Finsignsl strength in your home.
To get an extender and a new hub you would have to buy Sky's WiFi Max bundle see https://www.sky.com/broadband/wifi-max
The alternative is to buy your own WiFi system, connecct itvtomthe Sky hubband turn off its WiFi
Message posted on 02 May 2026 08:24 AM
Re: WiFi very poor
Having the same problems.
