Discussion topic: WiFi to Sky stream connection issues
Message posted on 23 Jun 2026 10:18 PM
Several times this week I have lost connection to Sky Stream. Service checker says my WiFi is good?
I cannot move my router due to open reach set up.
This constant loss of signal isnt great though.
Message posted on 23 Jun 2026 10:28 PM
Re: WiFi to Sky stream connection issues
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
