Discussion topic: WiFi terrible
Message posted on 04 Aug 2026 12:25 PM
WiFi terrible
I've had sky broadband about 3 weeks. The WiFi is terrible. Unless you are sat next to the router it's really slow.
The router is in the cupboard under the stairs, that's where the connection box is. It's not convenient but we managed fine with previous broadband supplier (bt).
Any suggestions??
Message posted on 04 Aug 2026 12:31 PM
Re: WiFi terrible
@Alexa8 wrote:I've had sky broadband about 3 weeks. The WiFi is terrible. Unless you are sat next to the router it's really slow.
Any suggestions??
All routers have differences but for any, under the stairs is a terrible position.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used and would be my own personal choice).
To run the local checker.
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
Helpful articles that explain the basics.
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
Link for Sky WiFi Max
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
Message posted on 04 Aug 2026 04:20 PM
Re: WiFi terrible
I agree with @Me134, I also went with a Mesh system which has been flawless for 2-3 years (both with TalkTalk and now Sky). There is an initial cost to purchase but then its yours with no monthly fee. Also makes moving to different providers very easy as you can keep the same wifi name and passord - no need to re-configure each device if you do change supplier.
Good luck with whatever solution you chose.
