Discussion topic: WiFi strength
Message posted on 22 Jul 2025 10:00 AM
WiFi strength
I've recently moved home(2 wks in), have broadband speed 75. The WiFi drops off in certain rooms. Boys saying XBox is lagging. Do I need the new WiFi box (not sure exact name) or do I need a package with higher speed?
Message posted on 22 Jul 2025 02:15 PM
Re: WiFi strength
@Caz212010 black or white router from Sky?
Message posted on 22 Jul 2025 03:50 PM
Re: WiFi strength
Black router that I brought with me from other property
Message posted on 22 Jul 2025 04:01 PM
Re: WiFi strength
Hi @Caz212010
If you find your connection is working fine in some rooms but not others its very likely you need a WiFi booster to increase coverage in that area. Boosters can be claimed from Sky for free if you have the broadband boost or Sky max addons.
I would note however that adding boosters to allow a connection of a gaming device like an Xbox could cause issues. This is because boosters sacrifice speed & latency for range so it could make the gaming experience pretty poor. I would look at using ethernet for the Xbox or perhaps powerline adapters/homeplugs if direct ethernet is not an option
