Discussion topic: WiFi stopped working
Message posted on 06 Jun 2025 07:24 AM
My WiFi keeps just stopping working and I have to unplug it and then most of the time it will start up again. But this happened twice yesterday and has happened twice already this morning
Message posted on 06 Jun 2025 07:27 AM
Re: WiFi stopped working
I need someone to look at my wifi as it intermittently stops through outvthexdsycwhich hinders my work as I work from home and need the internet
Message posted on 06 Jun 2025 07:41 AM
@SueM211
This is a customer led discussion forum where Sky customers are available to help other customers. You aren’t contacting Sky Customer Services by posting here.
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
