Discussion topic: WiFi still not working no engineer
This message was authored by: katiearding
Still no WiFi
Re: WiFi still not working no engineer
@katiearding
This is your first post so we don't know any history to this.
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
@katiearding New connection not working, existing connection that has stopped working, new upgrade of a system etc, you need to impart further so someone has an idea, all customers like you on the Forum and you are not talking to sky!
