Discussion topic: WiFi speeds low
This message was authored by: Paulfar
Message posted on 17 Sep 2025 12:29 AM
WiFi speeds low
Fluctuating speeds for WiFi Main hub in living room with only a stud wall and the xbox series X is on the other side Maxing out at 230 sometimes, but also dropping to under 100 when downloading I would expect a better WiFi signal considering paying for double the amount Your checker is based on the data going direct to the hub, which is not accurate to other devices in real time Please can you resolve Thanks
Find out more
Message posted on 17 Sep 2025 05:42 AM
Re: WiFi speeds low
Your are not talking to Sky as this is a customer helps customer community on here.
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
