Discussion topic: WiFi speed
This message was authored by: Camilla4
WiFi speed
Good evening,
I had a query regarding the WiFi speed room to room. In the room with the hub it is 843 but then a room upstairs only gives out 65?
Re: WiFi speed
@Camilla4
WiFi (and 5Ghz in particular) attenuates when passing through building fabric.
Re: WiFi speed
@Camilla4 Both are acceptable readings location wise with the hardware that you have and are using whatever it is! The links below may help assist you also!
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
