Discussion topic: WiFi speed droping down
This message was authored by: Marijus
Message posted on 09 Aug 2024 03:03 PM
Hi all, My packadge is ultrafast fiber besides guaranteed download speed to my hub should be no less then 100 mb/s. When i run speed test via google it keeps fluctuating. I've restarted the hub then for a second speed grown up to 110 mb/s, but after about 10 mins gone downt to 30/ 40 mb/s . Any ideas why? SKY app shows everything is ok and no issues in your area...
Find out more
Message posted on 12 Aug 2024 10:01 AM
Re: WiFi speed droping down
Hi @Marijus
Are you completing these tests over WiFi or ethernet? The speed is only guaranteed over ethernet.
I am NOT a Sky Employee
Message posted on 12 Aug 2024 10:31 AM
I'm WiFi connected
Find out more
Message posted on 12 Aug 2024 10:43 AM
That would explain why it is fluctuating. Are you able to test via ethernet?
