Discussion topic: WiFi signal
This message was authored by: CD7
Message posted on 26 Aug 2026 01:54 PM
WiFi signal
WiFi doesn't reach all parts of my home
Find out more
Message posted on 26 Aug 2026 01:59 PM
Re: WiFi signal
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
