Discussion topic: WiFi signal
Message posted on 28 Mar 2026 07:48 AM
WiFi signal
My WiFi doesn't work in my tv room/conservatory
Message posted on 28 Mar 2026 07:58 AM
Re: WiFi signal
@Matthew2019 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
