Discussion topic: WiFi signal
Message posted on 04 Dec 2025 02:11 PM
WiFi signal
Message posted on 04 Dec 2025 04:10 PM
Re: WiFi signal
@Julda Are you still using the old sky Broadband Hub on the connection with the old Sky Broadband booster, or did you change it and go sky Max?
Message posted on 04 Dec 2025 07:54 PM
Re: WiFi signal
No, I changed to the router provided when I switched to full fibre
Message posted on 04 Dec 2025 08:03 PM - last edited: 04 Dec 2025 08:06 PM
Re: WiFi signal
@Julda Not making it easy to find out what, so take a look and say which one you have by name!
And the extenders you are using also from the link below!
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
