Discussion topic: WiFi signal
This message was authored by: DianaE1
WiFi signal
Hi - I changed the box over to the new Max hub and now we can't get WiFi in any of the bedrooms. Was fine with the old box, and is fine in the downstairs lounge where the router is, but anywhere else it struggles to connect. Help!
Re: WiFi signal
@DianaE1
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
