3
This discussion topic has been answered Discussion topic: WiFi signal
This message was authored by: Keeefy
WiFi signal
Hi I have no wifi at home . Unable to do anything
Re: WiFi signal
@Keeefy
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
Re: WiFi signal
@Keeefy
This message was authored by: Osbrook
Re: WiFi signal
Not WiFi but your router cannot access the internet as there is another issue at 5he chesterfield exchange. Broadband is down.  Look at the router and you will see green, off, green, orange lights.  The off one should be green and once it is the orange one will go green.  Just got to wait for BT or sky to sort out the exchange server issue.
Re: WiFi signal
@Osbrook
The OP hasn't said where they are.
