Discussion topic: WiFi signal weak in kitchen and upstairs
Message posted on 08 Oct 2024 11:59 AM
We have fibre optic installed but find the wifi signal weak upstairs and in the kitchen. It is no better than it was with our last provider on the copper cable.
Message posted on 08 Oct 2024 12:11 PM
Re: WiFi signal weak in kitchen and upstairs
@BJ1949 having the fastest broadband service to your hub will not improve speeds in distsnt rooms if the issue is poor WiFi in your home. Sounds like you need to invest in a better home WiFi network. Sky will sell you their Sky WiFi Max sdd-on which can come with up to 3 extenders if an engineer agrees they are needed. Alterntively like many others you can buy your own kit with multiple satellite units.
