Discussion topic: WiFi signal poor
This message was authored by: Lewis19911
WiFi signal poor
Hi all,
Ever since changing over to Sky from Virgin the WiFi has been really bad. They both run off the same streaming set up and we never had any issues with Virgin.
I called up and went through various checks to processes to fix it but it only worked for, maybe, 12 hours.
we only have a small house and having to pay for upgraded WiFi just to run a small house doesn't seem right.
considering cancelling if it can't be resolved.
thanks
Re: WiFi signal poor
@Lewis19911 if you are paying for Sky's WiFi Max bundle Sly should send out an engineer if you do not havecusable WiFi in every room. The size of axproperty isxactually less of an issue than how it is built especially if you have solid internal walls.
