Discussion topic: WiFi range is terrible
This message was authored by: SkySye
Just changed from Plusnet to Sky and the WiFi range is much worse. I picked sky as the online info suggested it has the better hub, but now my TV in the room next to the hub can't even pick up signal. That combined with the less than minimum speeds 400mb on a 600 minimum guaranteed package) and that Skys help section seems to always be flashing up with "service unavailable" is not inspiring a lot of confidence in them.
Re: WiFi range is terrible
@SkySye Did you go white or black sky Hub with your connection?
Avatar for SkySye
White, whatever the default is not the max one
