Discussion topic: WiFi problems
Message posted on 01 Oct 2025 09:58 AM
WiFi problems
Message posted on 01 Oct 2025 10:09 AM
Re: WiFi problems
@skjennings24 Start with this link below and say if you see anything, wireless wi-fi is a complete minefield so the more detail you can supply the more possible solution may be found. And do keep in mind sky can help so do register the Vulnerable person status with them!
Message posted on 01 Oct 2025 11:40 AM
Re: WiFi problems
Could you explain in what way you can't get WiFi? Is your device just not picking up the signal from your hub or is there some sort of error when you try to connect?
