Discussion topic: WiFi problems
This message was authored by: NeilKennedy
WiFi problems
My WiFi keeps going down. Approximately 3 or 4 times a day at random times. Usually sorts itself eventually but never did this for years and does it all the time over the past 10 days or so. Did all the usual tests and checks
Re: WiFi problems
@NeilKennedy
If your Broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
