Discussion topic: WiFi problems
Message posted on 05 Jul 2025 11:09 AM
WiFi problems
My WiFi keeps dropping on and off- has been like this for around a week now
Message posted on 05 Jul 2025 11:23 AM
Re: WiFi problems
@Kim6725
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
Message posted on 05 Jul 2025 11:27 AM
Re: WiFi problems
I've got the same issue
Message posted on 05 Jul 2025 11:39 AM
Re: WiFi problems
Same advice. You'll need to contact Sky if it doesn't help.
Message posted on 05 Jul 2025 12:41 PM
Re: WiFi problems
Keeps telling me to report online which sends me round in circles. Can't get hold of a human
Message posted on 05 Jul 2025 12:43 PM
Re: WiFi problems
@Deb130
To call Sky dial 150 (free) from either a Sky Talk landline or a Sky mobile. Alternatively use this link…
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a number starting 0333.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number. (Customer Services in the ROI are not open at weekends).
The forum filters don’t allow the posting of full phone numbers on here.
Calls to Sky will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Message posted on 05 Jul 2025 04:41 PM
Re: WiFi problems
Thank you! I got through to someone
Message posted on 06 Jul 2025 02:53 PM
Re: WiFi problems
So they couldn't fix the issue but did try to upsell me a better package - not impressed may go elsewhere
