Discussion topic: WiFi problem
Message posted on 28 Jun 2026 09:50 PM
WiFi problem
Good evening, we have no connection on either mobile phones or sky glass but your checker says both broadband and WiFi are good? There is a red light on the fibre box which I don't know if that should be green or not? The router has a slow flashing green light
Message posted on 28 Jun 2026 09:58 PM
Re: WiFi problem
As you have Sky Fibre and your ONT shows a red light then have a read of this:
If that doesn't help then try running the line test here:
