Discussion topic: WiFi problem
Message posted on 22 Dec 2025 01:09 PM
WiFi problem
Message posted on 22 Dec 2025 01:37 PM
Re: WiFi problem
If your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
