Discussion topic: WiFi probelms
This message was authored by: Sammoores
WiFi probelms
Our WiFi box keeps loosing connection
Re: WiFi probelms
@Sammoores
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
