Discussion topic: WiFi playing up
This message was authored by: Shanell1
WiFi playing up
Hi there i have rebooted my sky box twice over the last 2 days and I keep loosing connection.
Re: WiFi playing up
@Shanell1 What is it you see when you look at the sky hub when connection is lost?
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
