Discussion topic: WiFi performance
This message was authored by: TobyFish1971
Message posted on 15 Dec 2025 11:00 AM
WiFi performance
I have an issue that whilst my broadband and WiFi test show good numbers in every room, video calls are regularly low quality in our home office, even with the device prioritised and no one else streaming. This happens with either of two newish laptops with high speed WiFi. Are there settings I can play with on the laptop WiFi or a way of monitoring WiFi signal over time not just as a spot check? I think I probably need a WiFi booster Alternatively what is the minimum broadband speed level I should have to allow smooth video calls.
Message posted on 15 Dec 2025 11:14 AM
Re: WiFi performance
@TobyFish1971 All the info you need is here in this sky help link!
https://www.sky.com/help/articles/broadband-speeds-explained
