Discussion topic: WiFi password
Message posted on 08 Nov 2025 10:16 PM
WiFi password
I received my sky broadband today. Where can I find the password to connect to WiFi
Message posted on 08 Nov 2025 10:23 PM
Re: WiFi password
A label with the wifi password will be on the back of or underneath the hub, have you looked?
Message posted on 08 Nov 2025 10:29 PM
Re: WiFi password
There should also be a card that came with the hub that it is printed on.
Message posted on 08 Nov 2025 10:30 PM
Re: WiFi password
There was no card and under the puck it's a Serial and WPS number only
Message posted on 08 Nov 2025 10:31 PM
Re: WiFi password
There's only Serial and WPS pin only
Message posted on 08 Nov 2025 10:32 PM
Re: WiFi password
It isn't the puck you should be looking at, it is your broadband hub (router).
Message posted on 08 Nov 2025 10:36 PM
Re: WiFi password
I only received the black small thing, nothing else I received. I was told I'm going to pay £35 monthly . I thought it come with the router for WiFi
Message posted on 08 Nov 2025 10:37 PM
Re: WiFi password
What did you order from Sky, so Sky TV or Broadband ?
Message posted on 08 Nov 2025 10:39 PM
Re: WiFi password
Broadband. That's what they told me about
Message posted on 08 Nov 2025 10:44 PM - last edited: 08 Nov 2025 10:52 PM
Re: WiFi password
I suspect you've perhaps inadvertently ordered Sky Stream (subscription television) alongside Sky Broadband, which is why you've received the television hardware ('puck') that gets sent out 'next day' wherever possible.
The internet router ('Hub') is despatched a few days before the broadband activation date, which is carried out on a completely different timescale to provision of the Stream device: this has undoubtedly confused many people before you.
Message posted on 08 Nov 2025 10:47 PM
Re: WiFi password
Thank you so much. What should I do now?
