Discussion topic: WiFi password
This message was authored by: Mihaela+V
Message posted on 26 Jul 2025 08:50 PM
WiFi password
I cannot connect to my WiFi with my phone. I did not change password and when I put the password it tells me is incorrect
Find out more
Message posted on 26 Jul 2025 10:27 PM
Re: WiFi password
If you are seeing an error about entering the wrong Wifi password then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as show on the hub itself so use upper case letting if required.
