This discussion topic has been answered Discussion topic: WiFi outage
Message posted on 26 Oct 2025 03:20 PM
WiFi outage despite saying it's all ok on the app
Message posted on 26 Oct 2025 03:30 PM
@Leah781
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again later).
@Leah781
Message posted on 26 Oct 2025 03:33 PM
Re: WiFi outage
I have the same, says no issues , yet I have no tv or WiFi on phone
Message posted on 26 Oct 2025 03:40 PM
Re: WiFi outage
The same advice applies @Kellee
