Discussion topic: WiFi on my pc is so slow
Message posted on 17 Sep 2025 05:29 PM
Hi there the WiFi in the household is running completely fine but just on my pc the WiFi is on one bar and the connection is terrible there is supposed to be 74mbps speed and I'm currently getting between 10 and 15 on a good day wondering if there's anything I could do? Many thanks
Message posted on 17 Sep 2025 06:09 PM
Re: WiFi on my pc is so slow
@Elliehow if your PC is in an area with poor WiFi signal level would it be practical to either move it or use an Ethernet cable? If neither are possible you may have to pay for extra equipment. If the PC is in a room fsr from the hub a powerline networking kit msybevthe answer asvthese use you home's mains wiring to carry the data.
