Discussion topic: WiFi off
This message was authored by: hollyMitchell
WiFi off
My WiFi have completely disappeared but my app is saying it's fine even though the box says there is no WiFi coming into the house it's ridiculous this has been happening every day
Re: WiFi off
@hollyMitchell
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
