Discussion topic: WiFi not
Message posted on 31 Oct 2025 06:56 PM
WiFi not
Hi. My WiFi isn't working I have rebooted and still not connecting
Message posted on 31 Oct 2025 06:58 PM
Re: WiFi not
@Angie97
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
Message posted on 31 Oct 2025 07:22 PM
Re: WiFi not
I have tried all this the box has a orange light on it. All other checks been done but I can't connect to the internet and nothing will load up
Message posted on 31 Oct 2025 07:36 PM
Re: WiFi not
@Angie97 What light is orange?
