Discussion topic: WiFi not working
This message was authored by: Aisha_1997
WiFi not working
My wifi has been down all day and nothings helped. The diagnostics is saying its working but its not.
Re: WiFi not working
Hi @Aisha_1997
You aren’t talking to Sky by posting here. If you are new to the forum then welcome to the Community which is predominantly made up of Sky customers helping other Sky customers which includes additional help from customers who are Superusers like myself.
Broadband and Wi-Fi are different. Broadband is the internet connection provided by your ISP (Sky), Wi-Fi is the wireless connection between your hub and devices.
Start by using this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
