Discussion topic: WiFi not working
This message was authored by: P3ul
WiFi not working
I've done test and you've said it's fine but it's not working - can you please get in touch with me to discuss[removed]
Moderator Actions: removed Peresonal details
Re: WiFi not working
@P3ul
We are customers here in ho help each other.
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
@P3ul
You aren’t actually contacting Sky by posting here as this is a customer ▶️ customer discussion forum where we try to assist other customers.
No one from Sky will contact you as a result of posting on here. Any Sky account/s you may have are not linked to your Community Forum username so no one knows who you are.
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
