4
This discussion topic has been answered Discussion topic: WiFi not working
This message was authored by: TonyG1977
WiFi not working
Not working despite check saying fine and lights on
Re: WiFi not working
@TonyG1977
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
▪️I AM NOT A SKY EMPLOYEE ▪️
@TonyG1977
@TonyG1977   First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
This message was authored by: Gc37
Same
@Gc37
Same advice.
