Discussion topic: WiFi not working
This message was authored by: Jessie29H
WiFi not working
Hi my internet isn't working the internet light is off and the voice light is orange
Re: WiFi not working
@Jessie29H
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
