1
This discussion topic has been answered Discussion topic: WiFi not working
This message was authored by: MichaelBrandon
WiFi not working
My wifi on here says it's working but I have a orange light displayed and it's not working.
Re: WiFi not working
@MichaelBrandon
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
▪️I AM NOT A SKY EMPLOYEE ▪️
@MichaelBrandon
