Discussion topic: WiFi not working
Message posted on 03 Apr 2026 09:04 PM
WiFi not working
WiFi not working
Message posted on 03 Apr 2026 09:09 PM
Re: WiFi not working
@Ally931
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
