1
This discussion topic has been answered Discussion topic: WiFi not working
This message was authored by: Danielmfbbq15
WiFi not working
Hello, my wifi has recent been going off randomly and won't connect again untill I switch off the power to the fiber hub
Re: WiFi not working
@Danielmfbbq15
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
@Danielmfbbq15
