1
This discussion topic has been answered Discussion topic: WiFi not working
This message was authored by: harrisonsmith82
WiFi not working
you're saying there isn't an issue with my WiFi but I can't connect to the internet on my router the power and WiFi are green but the internet is orange and we can't connect to it
Re: WiFi not working
@harrisonsmith82
You haven’t contacted Sky by posting on here. This is a customer ▶️ customer discussion forum where we try to help other customers.
@harrisonsmith82
