Discussion topic: WiFi not working
This message was authored by: Debbie012
WiFi not working
WiFi not working
Re: WiFi not working
@Debbie012
▪️I AM NOT A SKY EMPLOYEE ▪️
@Debbie012 Is the wired Ethernet connection working on the Hub or are you not using that? Also is the WiFi light out or not Green on the sky Hub if you have that unit with the multiple lights to show that, would be the third from the left as you look at the Hub, link below if you need to go look at the various types?
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
