Discussion topic: WiFi not working
Message posted on 06 Feb 2026 10:57 AM
WiFi not working
My WiFi checker says it's all fine but I have an orange light on the voice option and there is no light on for the internet
Message posted on 06 Feb 2026 01:00 PM
Re: WiFi not working
@Hollie48
