Discussion topic: WiFi not working
This message was authored by: Naomi_
WiFi not working
My box has two out of the 3 green lights on, but no internet. And the service checker says it's fine, but it's not.....
Re: WiFi not working
@Naomi_
With any broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
